I have replaced the Hot & Cold taps for my sink in a second bathroom & i have a problem with the Hot tap.
After installing the taps i have not had any problems untill say 2 months down the road.
When i turn on the Hot tap the pipe starts to bang like a machine gun & then the noise stops and the water runs fine,i thought it might be air so i let the tap run for a while.
The noise does not happen all the time when the tap is used which is odd.
I have also noticed sometimes after using the Hot tap that after turning it off say 10 minutes later i can hear water running,i return to the bathroom to find the Hot tap running as if i did not turn it off.
The Cold tap works perfect,never a noise & never running after turning it off.
Please can anyone advise as to what my next step would be in fixing this odd issue,thanks very much.
