Banging!
11 May 2007
Essex
Just had new combi boiler fitted (worcester) replacing the old back boiler. All fitted well and working fine, except now when the cold water is opened there is a loud bang, (only very slight bang on hot water) just the one then fine, no noise when closed . Can't locate the noise for sure but seems to be coming from the loft, checked new pipes, all seems ok .
The kitchen sink and washing machine water supply is only a foot or two of pipe to the mains supply downstairs so not sure why should that bang when opened?
Was all working quietly before so i'm a little confused as to what's causing it!
Any idea's before I have to call him back?
Thanks..
Thanks for reply, just tried that, did open a little bit more but didn't make a difference to the bang!
If its coming from the loft, then there is a possibility that the installers have connected the old storage tank inlet pipe to its outlet pipe as a way of converting to mains pressure cold water.
If the pipes are close together, or not well clipped, that could explain a movement when pressure is relieved by opening a cold tap. Solution if that's the case would be fairly obvious.
