Banham Eurolock cylinder
14 Jul 2016
Trying to remove a cylinder. Appears to be two screws that keep it into an outer cylinder. Are these grub screws using a very small Allen key? Anyone had experience of these?
Update. Used a mini-allen key to remove the outer part that runs over the protruding eurolock cylinder on the outside of the door. The Banham cylinder is a L111 Eurolock cylinder. Banham are very expensive and I believe keys can only be cut by them, very expensively. Others make Banham compatible cylinders for about half the price.
L111 fixing instructions attached. The grub screws are mentioned there.
  • Banham-L111-Fixing-Instructions.pdf
