Banister and Staircase
16 Apr 2006
Cardiff
Hi
I need help with a project i need to tackle but havent a clue where to start. In the house there is only a top handrail which attacheds to the one newel post which has split. i need to replace this but havent a clue where to start as cannot see how its attached toe floor etc.
Sorry if this is a rubbish post but it is hard to describe, would appreciate any help or references
Many Thanks
Darren
Hard to advise without pics, I'd suggest having a poke around, carefully! They are usually fixed to the floor joists, so you'll have to get the carpet up.
Hi guys
further to the post I have cut off the old split newel post, it is the newel post on the landing, there is no handrail running to the bottom of the staircase, only a straight landing.
Well as i said I have cut off the old split newel turning and had to cut a bit of the the newel base, now I have a dilema, I have bought a new newel turning which is to be attached to the unfortunately shortened base, now if i did this the handrail will only reach a height of 800mm, and i know this is too short.
What do i do? Do I tray and build the newel post up in height by addaing a new bit of wood or replace to whole newel post which is my leats favoured option as its very solid and i dont want to disturb it by probably replacing it with a not so rigid one.
Or to i just go with a height of 800mm
Any suggestions would be really appreciated, if i was to build the newel base up how best to do it, im thinking glue and maybe a thick dowling in the centre, dont really want to use screews as im not painting it i want a wood finsih
Well replacing the whole newel post would be the right thing to do, it's solid for a reason, to make sure you don't fall arse over tit when using the handrail. Stairs in general are supposed to be rigid throughout their construction.
I'd suggest reposting this in the carpentry or stairs section for more detailed answers.
