Added a radiator to a sealed worcester 28 cdi system, bringing it upto 10 rads. Took new rad off a rad in the back room with plastic piping. However after fitting the rad the pressure drops by sometimes upto 1 bar a day to under 0.5. The CH/Hot water still works, but hot water has twice gone cold during hot water flow. Switched off demand and tried again and it works fine. Thought it was the pipes linking the new rad which is under solid wood floor, did not want to lift floor so decided to cut the plastic piping and sealed them (removing new rad from system). Pressure stayed at 1.5 bar, however after two days pressure began falling again to above levels, checked the fittings on the back rad and there is no leaks. Looking for any clues?
