I'm looking to change my microbore pipes to plastic for central heating is it ok tpo this I'm doing 15mm copper from rad but what is best under floor thanks
You could do the hidden pipework in 15mm for each radiator if you wished. Best it comes off 22mm pipes usually for large rads, or if doing 2 or 3 small rads from 15mm.
You need to support and clip the pipes.
Use correct insert supports to suit brand of barrier pipe.
Personally I always use copper.
Using 15mm to rads will be better than the microbore for flow rates.
You will need rads and rest of system balanced later
