I'm adding a radiator in the utility room as it currently doesn't have one (its the end of the garage!) and I can tee into the 22mm feed and return pipes with 15mm and I was thinking of using plastic barrier pipe but I've read that mice could be a problem (it'll be under the ground floor floorboards and we do get the occasional mouse in the house, living near fields).
So, to the point, what can I do to protect the plastic pipe from the nibbling little blighters?
I do set traps and manage to catch them but I guess they're quite often under the house so could be nibbling without actually gettting into the house itself hence my concern.
I could use copper but it'll be somewhat tricky to feed the pipe under the floorboards without bending whereas the plastic pipe will obviously be reltively simple in comparison.
