I recently had to dig up a small section (approx 1m x .5m) of the tiled pathway in front of my front door to run a new water main into my flat.
The main is now in and it's time to fill the hole (approx 300mm deep). I am assuming I lay in about 200mm of hardcore and then pour 100mm of cement (4:1 ratio) and let it set. I have to re lay the Victorian tiles on top of that.
Does that sound right? Is 100mm thick enough? Is a 4:1 sand:cement ratio strong enough?
Any advice gratefully received.
