I am going to be doing my driveway in a couple of weeks so want to get some advive. Firstly a car will be going on it and i will be using 50mm 2ft x 2ft flags. I have read you need a 100mm sub base (type 1) then 50mm sharp sand whacked then lay flag. Few questions
1) Is 100mm Type one needed or could I use 50mm then a wet mix of
screed mortor ?
2) There is houses getting built by mine and they are in the process of doing the drivewasy and they have ust used shingle or limestone as a base and thats it? There are the builders what have built a full estate of houses, is this a better and easier way, if so what is the price difference between type 1 and limestone ?
3) What is the best way to get your levels of sub base and sand on sloping drive, How would I do this with thimber if not putting any borders in just flags ?
screed mortor ?
