Hi all,
I am doing the plumbing/tiling for a shower installation in my flat (my brother in law is a qualified electrician and is doing the elctrics), and I have what I hope will be a simple query.
I am taking a feed from the cold water tap in the bath. I have chased out the wall and intend running the feed behind the tiles straight up to the shower inlet. In order to easily get around the bath into the chase I want to run a flexible hose from the bath cold water feed. (I will use a 't junction' (incorrect name I think, but never mind) from the cold water feed, put in a full bore isolation valve, and am happy I wil have the right size connectors between the various components).
I have a piece of 15mm copper pipe, but believe it will be simpler if I can buy a flexible hose 150cm, which is the length I need to go all the way from the cold water feed to the shower inlet (the alternative is 300mm flexible hose to the copper pipe from the cold water feed / from the pipe to the shower inlet). I know the grout from the tiles will corrode the copper if I don't wrap it in something, and think it more likely that the joints will leak rather than the actual pipe, and need flexible hose at the shower end (the flat is in a block which, it turned out, is made of very very tough concrete, so it wasn't easy chasing out (so need the flexible hose to meet the shower inlet) - hence me preferring the flexible hose if possible...
The only flexible hose I have found is this:
http://www.screwfix.com/p/wras-hose-15mm-x-1-2in-x-1500mm-x-10mm/41845
I could use this, but am concerned that the bore of the pipe is only 10mm. I get that it is possibly a difficult question to answer, but would the smaller diameter of this pipe cause a problem, or would it most likely be ok? Is flexible hose ok for a shower full stop? Ideally I would like 1500mm 1/2in 1/2in 15mm flexible hose but can't find it anywhere, does flexible hose in this dimension exist? Is there anything else anybody can see I am doing wrong other than my hose query?
Apologies for the long post - have tried to get all the necessary detail in there.
Thanks so much for your help appreciate it!
All the best, Ron
All the best, Ron
