After 2 years of my MFi bathroom suite living in the spare room still in their boxes I have finally got some time off work to be able to fit it, but have some queries now that I've stripped the room.
1) The hot water from my Combi fed the bath tap via a 22mm pipe which T'pieced off to a 15mm to also feed the sink tap. Do I need to retain the 22mm feed to the baths hot tap (bearing in mind that the old pipework was designed for a very old back boiler system) or can I split the 22mm hot water supply to two 15mm pipes?
2) If I have to use a 22mm feed for the bath can I fit an isolator inline without reducing affecting the flow rate?
3) Unless it comes down to personal preference, should I use copper pipes to join the mains & boiler copper pipe supplies to the batroom suite? Also, should I join the pipes with push fit or compression joints?
4) If bath taps & sink taps have standard thread sizes, what are they as I need to get these.
