- Joined
- 5 Sep 2016
- Messages
- 63
- Reaction score
- 2
- Country
I've been having some hair brained ideas for insulating my cheap steel slat garage roller door. I want to use the garage for odd jobs through the winters and the internal temperature is currently equal to the outside temperature which dipped to minus 6 this week and nearly killed me even though I was wearing 4 layers looking like Michelin Man!
The roof is fibreglass over osb2 board and will need insulating but I think the door is my biggest issue for starters. The roller at the top is not boxed in so it is impossible to heat the space because there is so much air flow coming in/going out. As well as this, the steel roller obviously gives no protection whatsoever in itself. This leads me to the following for discussion if you'd be so kind to indulge.....
To try and cut a long story short I want to try and insulate the whole area (the whole area floor to ceiling including the gap above the door) somewhat.
First I'd like to make sure that I understand how insulation works.....after some googling my understanding is that air is a poor conductor of heat and that it is a good thermal insulator in its own right. I also gather that having an air gap is all very well and good but if there is convection allowing air in and out of the cavity then warm air will always be able to escape from the space being heated, basically heat loss so heating the space is more difficult. So trapping the air and therefore stopping convection is the key which is why polystyrene foam (98% air) is a good insulator?
I'm tight so have been thinking of the cheapest way to tackle this. The door width is approximately 3m and about the same from floor to ceiling. I will need to easily open and close the insulating partition when a car is in situ. I want some sort of semi permanent construction that can either be removed in sections and stored overhead (something like 50cm wide panels) or a concertina type setup that can be hinged at one end of the door and pushed out of the way. I'm not too bothered if they aren't super solid so I am considering making relatively lightweight panels out of 25mm batten with 3mm hardboard sheets either side. I can figure out some system of mounting, hinging, latching etc but I'm considering filling the void in between the panels with polystyrene foam packing chips (packing peanuts) as I can buy enough of this material to fill the whole area for £12. Alternatively I have considered assembling the panels with sealant to trap air internally in the panels, would this have the same effect as filling with polystyrene foam?
Any thoughts on this much appreciated.
Thanks in advance....
