basin mate problem
18 Nov 2005
Fitting a new basin blight a basin mate because it wouldn't seal
Now following the instructions and everything as it should be the foam white washer that goes topsode between waste and basin just won't seal al all
Any tips?
Throw basin mate away, I don't use it.
The correct way to use plumber's putty and poly washer. I only used silicone on silly design basins.
Daniel.
Managed to sort the issue
Uses the basin mate but alto used the thicker washer topside that came with the waste
So far no leaks hot or cold and the basin is still full and not in the bucket underneath
Always the first thing I do when fitting a basin. Unscrew the back nut and chuck the foam washer in the rubble sack.
