I am replacing a basin and the waste is lead and buried in the wall. Is there any way to connect plastic to lead? I am not in the position to channel out the wall.
Yes. Depends on the size of the lead. If it's close to the plastic size a normal plastic compression fitting will be fine (some makes eg McAlpine may need their inner tube trimming out). Otherwise there are "rubber tube with hose-clip each end" fittings available which fit everything.
