Basin with round tap holes
5 Jun 2011
Gloucestershire
Back when I was alive, basins had square holes and taps had a square on the bottom so they don't move when you shut them off.
Mind you, even 30 years ago that started going pear-shaped, I remember putting new taps in an old basin where I created the squares on the taps by locking two brass back-washers onto each tap with Araldite then filing them to a square, but then the basin had squares so it worked OK.
Picture...
And yes, I made the cupboard from an old laboratory worktop, a sideboard and some oak flooring, and I did the tiling. But then I had all the time in the world or thought I did.
Anyway, now I see that common sense has been totally mislaid. Now the taps have no square and the basin holes are round.
How is one supposed to fix them so they don't rotate?
They often come with a rubber washer to tighten on to so it grips whilst also providing a bit of cushion against the ceramic.
Top hat washers (split click are one type) were designed to create a better, more stable and self loosening resistant fixing system for basin/sink taps. They do actually work but not required if, as suggested, a tap when properly fitted and tightened shouldn't really come loose. anyway
Tap connectors don't need too much tightening (less than eg a compression fitting) so if the tap is tightened well, as others have said, it shouldn't be a problem.
You can use a tapmate washer and a brass backnut for that "no-one's ever going to wiggle this" approach but it's rarely needed.
The old classic 72000177!
