Right then. I'm renovating my bathroom, well actually I'm ripping it up and starting it again! So far so good, but I have two questions:
1. The basins (yes, plural, 'His' and 'Her Indoors') are ceramic half spheres which sit atop a worktop. The questions is, should I use the nut on the waste to secure the basin to the work top (aswell as the basin to the waste obviously) or should I leave that to do just the job it was designed to do and find some other way of securing the basin?
2. The wall mounted taps (similar ones here ) consist of three separate parts joined together by compression fittings.....and they are leaking! Not all of them, mind. I have read almost every posting on here (sadly not BEFORE I started) and am aware that what I shouldn't've have done is tighten then up as much as humanly possibly...but i did. What can i do now? Surely, loosening them off isn't going to help? Will covering the thread in PTFE (or is it PFTE? I never bloody know) help, or is that (as has been suggested by more than one person in here) a plumbing crime? Is there any other substance i can use to help seal the connection?
Any help would be greatly appreciated, Aidan
