I have a standard Steel bath which I brought a long time ago from Homebase and have managed to lose the 'reference adhesive strip' that is supplied to stick on the underside of the bath to help you position the plastic support feet correctly. The bath is 1700mm x 410mm (ex feet) and I was wondering if anyone can advise on the position to place the feet. I don't see as it would matter that much if I use common sense and place about 100mm from the waste outlet and a similar distance from the other end, but I guess the manufacturer thinks it is important as the instructions show a diagram showing the reference strip with various position depending on which model you have. No distances are given and you would still need the strip to mark the position on to the bath. I will try to phone homebase on Monday but I doubt they will be able to supply.
