Bath fitting
24 Aug 2004
When replacing a bath is it necessary to chase out some of the wall plaster to fit the bath edge in to? Some DIY guidance says you should and some doesn't mention it at all :confused:
If you're replacing a bath, you might as well go with the flow (forgive the pun). If it has been chased out, leave it chased out, if it hasn't, then don't.
