Bath Height
19 Aug 2005
Is there a standard height at which a bath should be fitted from the ground.
Im framing and tiling it, but if i ever change to a panel do i need a standard height to set it to now so i dont have problems later?
Thanx
Unless you want one of those godawful cheap plastic things which last untl the first toddler-kick, you can buy wood/mdf panels which have a plinthy bit about 180 tall, which is used for adjustment. Std height is 500 (I think).
I always fit them as low as possible (easier to get in and out of). The limiting factor is usually the need to accommodate the trap, but with special bath traps and recesses in floor boards, you can get quite low.
