Bath Hot Tap
21 Nov 2011
Hi
I had a new bathtub and mixer tap fitted 3/4 months during the summer.
Recently there has been times where by the hot tap turns a little and then stops, its not stiff just won't turn any further.
If I go back to if an hour later it turns fine, not sure if's related to water pressure or the boiler being on?
The cold tap of the same mixer unit works fine, and all other hot taps in the house are fine.
As it works some times and not others, that would rule out a washer of tap spindle issue I presume?
Can anyone advise how I can troubleshoot the issue further?
Ring the original installer if he supplied tap and get him to take a look, would still be under warranty
