Hi all, roof done. Solid as a rock and dry as a bone. Onto the bathroom.
Bit of a logistics issue here. The bathroom is 1710mm wide from block wall to block wall with all plaster and render removed.
We are looking to get a bath to 1700mm long and install it in this gap.
Walls above bath will be tiled to the ceiling.
Naturally, there isn't enough room to plaster the walls before we put the bath in.
Looking for options here, so far, I've only got one, and that's to fit bath, then plaster walls around it accepting that the plaster will be past the edge.
Only problem is, I don't know what the logistics will be with regard to fitting panels, chances of leaks... etc
Any thoughts?
Cheers,
Fubar.
Any thoughts?
Cheers,
Fubar.
