Bath Installation - How To Prevent Squeaking?
12 Apr 2008
Dorset
I'm almost ready to fit a new bath to my bathroom. I'm going to put a batten on the 2 walls that the bath will sit against so that it is really secure.
Someone else who did this found that the rim of the bath squeaks when it moves against the battens that it sits on. What can I put between the battens and the rim of the bath to stop this?
If the bath already has a batten bonded to it I wouldn't bother. Brackets on the 3 wall corners will keep it steady enough and the sealant will accommodate any movement.
Do the instruction specifically mention you need battens to rest the bath on? Most baths are perfectly ok if the feet are properly installed and the edges silliconed to the wall.
Thanks for the replies. No the instructions don't mention using battens, but I want to secure it really well. Is securing the feet to the floor and siliconing the sides really enough?
If the instruction say: just feet and silicone, that's what you should do.
