Bath was fitted about 20 years ago and there was a leak about 10 years ago where the water was coming through the downstairs ceiling. The wife called an emergency plumber on the home insurance who came out and said oh, the bath waste pipe is leaking so he tightened it up and that was "fixed" until today when the downstair ceiling started dripping again.
The bit where the black piece meets the bath feels wet and around the lower white bit. I don't know if the crusty crud is limescale or failed sealant.
How to fix this? Take the whole thing off and replace? Is this just going to be a crusted worn washer, the "sealent"/"cement" around the top of the black bit?
How does the black piece fix to the actual bath? is it s crew fitting? Are these a standard size? if not what do I have to measure?
(I spent an hour in local toolstation recently while they tried to find a replacement "50mm" washer where everything they had was labelled differently either ID or OD)
Lastly, is this something that has been sealed by the crud until mr muscle was recently poured down?
