Looks simple enough. Remove one set of taps replace with another.
Turned off all stop cocks in the house and in loft.
Thats the mains under the kitchen sink
The valve cock to the immerser and the HOT out valve. The 3rd valve was already off feeding the emerser.
3 valves in the loft - one at the bottom of the tank, a valve into a small tank ( don't know what that was for) and one pipe that came through into the emerser cupboard.
I also had all taps running to empty everything.
START
Made sure there was no running water from any tap or shower.
Managed to remove the taps ok - it was a squeeze to reach in the tight space but managed it ok.
As soon as I removed the taps from the pipes water leaked out from the pipes and although I tried to fit the new ones quickly it became a bit stressful as too much water was trickling out.
I re-fitted the old taps no problem and stopped the flow.
QUESTION
Why was there a trickle coming out of the bath tap pipes when nothing was coming out of the taps when connected?
Is there another valve / stop cock I missed.
START
QUESTION
