Hi all ive just recently fitted a bath mixer with shower and the problem ive got which i didnt realise before hand is that the hot is gravity feed and the cold is mains so things dont work to well , can i fit a pressure reducing valve to the cold tap feed so i can equalise the pressure maybe as a permanent fix or tempory till i have time to run a new gravity feed from the cold water tank in the loft which i guess im going to have to do if later i want to fit a pump
Cheers
Darren
Cheers
Darren
