Bath / mixer tape isolation valves
3 Apr 2010
Cambridgeshire
Hi
I'm going to have a go at fitting some new bath / mixer taps.
The current 22mm pipe work to the taps doesn't have any isolation valves fitted.
Not sure if i should fit standard iso valves or go for the steel flexi type with the isolation valves combined. Which is best?
(Being a novice type I'd prefer the easier of the two)
Thanks in advance
I'd use separate valves and flexible tap connectors. That way you can disconnect the connectors at the lower end (not the tap end) if the tap needs to be removed. Tiny bit more work up front but could save much swearing later.
