Bath panel glue
20 Dec 2006
Stirlingshire
Quick question - easier than my usual ones :)
My bath is one of those double curve ones that has a shower bit and another curved section so the bath panel is an unusual shape. Sadly the panel is cracked along the top where it starts to form the lip.
I don't know the make/model of the bath so cannot for the life of me find a replacement. So short of replacing the whole bath, I would like to try gluing the big crack, which is maybe 3mm at its widest.
As it'll be wet on and off and will likely get at least a little movement as people lean on it, what is the best type of glue to use? I think the panel is plastic.
Thanks.
Remove the panel and get a fibreglass kit from halfords or similar and apply it to the rear, if you're lucky you won't even know it was cracked in the first place, I did this on a bath panel in a house I lived i
