Bath Panel
28 Aug 2005
Essex
Have just fitted steel bath,now trying to fit acrylic panel,could some one tell me please how to stop the top from pushing in.At the moment its just the tight fit to the wall thats holding it there.
Many thanks
Brian :oops:
Plastic bath panel clips, don't know where you can get them separately though. They are like spring loaded V shapes and you put them into the bath rim recess upside down like this /\, then slip the panel in between the clip and the front rim, so you have B/\PR, where B=bath, P=panel and R=front rim.
Many thanks,will shop around,or failing that will try a frame
Brian
Only needs a bit of wood stuck under bath rim with solvent type gripfill :idea:
