Hi all,
A weird problem's developed in the last 2 weeks in the upstairs bathroom.
When we flush the loo it causes the water in the bath u-bend to gurgle and splutter violently. In the last few days it's become worse and the toilet now fills up to a high level when flushed, before quickly returning to its proper level. Running the sink at full blast also now causes the gurgling in the bath (but to a lesser degree).
I thought there might be a blockage, but both sink and bath drain quickly, but I shoved chemical unblockers down bath and sink and I've plunged the toilet, these things seemed to help but only temporarily.
If it helps I'll describe the configuration of the pipes. This is the view from the garden looking at external pipes at the back of the house coming out from the bathroom:
external
air vent...................toilet waste........bath waste pipe
|| <extension>
to ground
So basically the toilet waste comes straight through the bathroom wall out into a wide waste pipe, which runs almost horizontal along the top of an extension and then straight down into the drain on the left. The smaller bath pipe comes out the wall and runs into the end of the bigger main waste pipe. I think the sink merges with the bath pipe at some point.
Any ideas what I can try?
Many thanks
Simon
external
|| <extension>
to ground
Many thanks
Simon
