Bath Problem
29 Jun 2005
Clwyd
Had a problem over the past few weeks of the bath leaking around the edge as it meets the tiles and also from the plug hole area, so taking the bath out today to fix these problems, scrape all the silicone off etc.
The bath is a Plastic fibre glass type, with the metal from and dodgy bolt feet to keep it up, can I put blocks underneath the bath between the floor and the piece of chipboard glued to the base of the bath for more support or will this cause problems?
Reason I want to do this is to reduce movement of the bath from the wall, room not square so big gaps around the bath.
Any advice appriciated,
Gareth
we had a similar problem, particularly the plug hole area.
upon closer eyeballing the centre plug hole screw was loose, tightened it no more leaks.
my mother had similar but worse (water on floor) the plughole area had actually cracked - new bath to fix problem
why take bath out only to put it back where it was?
remove old silicone (sitting in empty bath its not too hard) clean area where silicone was, fill bath with cold water, re silicone it allow to to dry then empty bath, oh and check plughole scre first
Cheers mate will check that to see before I take out, still need to take out to redo the silicone.
dont see why you have to take bath right out, still i cant see what you can see
