Bath Problems
15 May 2007
Leeds
So moved in to a new house 2 weeks ago now .
Bath is flexing at opposite end to taps and is coming away from the wall.
So i have taken the panel off to have a look. The legs were on tiny square blocks.
I was going to run 3x2 from the back legs to the front . I have put a pice of hardwood under the back leg to give you an idea . The beam runs under the floor in red as you can see the back legs are resting on the chip board floor and flex.
Would this work if not can you give me suggestions on what to do ?
Many thanks .
Regards Ratty
[/img]
New as in brand new build? You could get the builder back, but your plan looks fine to me and should be fairly easy.
