Hi all,
A friend of mine has a bath / mixer tap, the sort where the shower hose sits on a built in cradle and you switch between bath or shower by moving a lever. Problem is that the hot flow out of the shower head is barely more than a trickle and has apparently got worse over time which. I took the cradle bit off to see inside but apart from observing that a bit inside moves when you operate the lever didn't really achieve anything.
Is this likely to be a water pressure issue or a problem with the lever mechanism? I don't want to suggest buying a new tap only to find no difference.
Many thanks,
David.
Many thanks,
David.
