hi folks ,
I am going to have a bash at replacing my bathroom suite
Couple of questions present themselves:
1. Can someone name the tool that is used to remove the nuts from the hot and cold bath taps. I think the hot is 22mm and cold 15mm pipe.
2. I have a gravity fed vented system, would I need taps that work at low pressure ?
3. I am planning to use plastic piping instead of copper as this is what the pro plumber did at my mums house , is this acceptable ?
I am going to put an isolator valve in the 22mm hot water piping so that i can isolate the supply while i am farting about putting the loo, bath and sink in. Now I have noticed that the isolator when open reduces the bore to approx 15mm , is like to cause any flow issues ?
Many thanks in anticipation
