I need a need bath tap mixer. Looking on screwfix website most of the widths are 226 or similiar. I measured the distance from the middle of each tap to the other and it's only 180. Should I be looking for 180mm tap mixers only?
Most (but not all) bath deck mixer taps have 180mm between the centres of the hot and cold inlets. If this is what you have now, its what you need for the replacement.
