I have a mixer bath tap which has a shower hose attachment
There is a divertor that diverts the water to the shower
Recently the hose started leaking, so I replaced it
However, since that time, the shower divertor has not worked fully:
some of the water is still coming out of the bath tap
It's difficult to estimate, but I guess around 20% to 25% is going through the tap
The divertor mechanism is an annular ring just below where the hose is attached.
To divert to the shower, the ring is pulled upwards.
If I try and forcibly pull the ring up, water still comes out of the tap
Does anyone know if this can be repaired, or is it likely that the situation will get worse - and I will eventually have to replace the taps
Thanks for reading and any help
