We moved in to our new house two years ago. We've had a plumber round recently to have a look at putting us in an outside tap at the rear of the property and he has raised a couple of concerns over the fitting of our bath.
View media item 19197The bath in the property has been fitted with a shallow seal bath trap, the plumber tells me it should have been fitted with a deep seal bath trap to prevent foul gases entering the property from the waste pipe. Is this correct?
I contacted the Builders who built the property and their answer was as succint as they always are - "the property met NHBC inspection and we do not believe there to be a problem".
Also, as you'll see from the picture below the middle support on the bath is hanging in mid air, it has never been fitted correctly. The builders said they did not see this as being a problem either.
Any views to either issue would be gratefully received.
Thanks.
Thanks.
