Hi.
The overflow on our bath doesn't work properly. Water doesn't empty down it fast enough to stop the bath overflowing if forgotten about.
Our water pressure is terrible and the bath takes about 20 minutes to fill to a reasonable level. We set timers but sometimes the lad forgets and we get flooded.
The bath empties just fine through the plug hole.
I had to change the U bend a while ago and I noticed the resting water level is just below the level of the U bend. It's pretty much at floor level which means there is always water in the pipe that takes the bath water away?
Is this normal? Could it be the problem? The pressure of the bath water from the plug could be forcing the water down but the lesser weight of the water from the overflow means it doesn't empty quick enough?
I hope this makes sense.
Whatever the reason, I'd appreciate some guidance as what can be done about it.
Thanks a lot.
Thanks a lot.
