Hello Helpers
The answers are probably on here, I have looked through the topics and found it very helpful but I need to be sure I'm on the right wave length.
Plan is to take out old bath and replace with nice new one and move te sink over!
Plumbing is as follows.
In the bathroom 15mm hot connects to 22mm under the floorboards which then has a T up to the bath taps, still 22mm. This 22mm continues under the floorboards, feeds the sink via a 15mm from a T junction. The 22mm pipe is then capped off, I assume where the old hot water tank was. The cold water pipes follow the same pattern.
Do I need to stick with 22mm pipe to the bath? I now have a combi boiler rather than the old style central heating system with hot water cylinder.
I'm also wanting to have a shower over the bath run off the taps i.e not a separate thermostatic shower, will the pressure be ok from 15mm pipe?
Rachel
Rachel
