Hi there, I'm a diy novice and looking for help. I am going to get my bathroom replaced and thought I would remove the tiles as, you know, it's easy right?!
Anyway. Now I've done this I do not know what to do. I've added some pictures to show what I mean.
Two walls are stud - the other 2 brick. The plaster behind the tiles had blown on 1 so I kind of took it back to brick. The other wall used to have a door there.
There is a lot of crumbly stuff. It's an old building that was converted to flats about 20 years ago. There's a l&p ceiling w some lovely cornicing that I really want to keep...
Please can I have some advice?
Where do I go from here? Do I find a plasterer to re-plaster the two non plasterboard walls (they're not even and the bits around the door frame are crumbly still)? (What do they use?!) Do the other walls need plasterboard replaced (they were a little damaged and there is signs of water ingress)
I don't know if I need a) plasterer b) bathroom fitter to help me.
I'm feeling a bit overwhelmed so thank you for reading.
