I replaced a bulb in my bathroom plastic light (basic three spotlights) - I noticed the bulb was difficult to screw in and next day switched light on and it exploded - glass everywhere. The only other light in the bathroom is an over the shower downlight fitted a few years ago when we had bathroom done. Both come on from the pull switch.
Anyway I couldn't get the base out so I've removed old fitting and intend to replace. Lots of wires but it looks simple, there is a final connector block with 2 wires which was then wired in to the live and neutral of the light fitting. Only thing I've found odd is that there was no connection to the earth and the earth wires are just pushed up into void. I can't see that the old fitting was marked double insulated.
Has this been fitted wrong from my description? Should I buy a double insulated fitting and then just wire up using existing wiring, or should I be asking an electrician to look - bothers me that no earth connected originally although a friend tells me this is very common.
Advice appreciated (pressure to get new light up asap as visitors tomorrow...)
