Hi - I'm hoping I'll be able to get some advice ....
We have a vented, gravity fed system with an expansion tank in the loft. There are 15mm pipes upstairs and 8mm downstairs. We've done a lot of work to balance the system to get reasonable heat downstairs.
However, my question is about the 2 bypass radiators in our bathrooms. When hot water is heating these radiators heat up too even when the heating is off. When a plumber came recently to fix a new radiator he noticed the T valve for the bypass in the airing cupboard and turned it right down to restrict the flow to the bathroom rads. He said it would increase flow downstairs to the 8mm. This has increased the heat downstairs and I've noticed the boiler isn't firing so much, which is good. However, it has created some noise issues:
- we now get what seems to be hissing pipes / TRVs on the 15mm pipes and to some extent on the 8mm too;
- the pump (which is set to 3) seems to be more noisy and like it's struggling somehow?
- the boiler is really loud when it first fires up and then seems to reduce output.
I have two radiators open continuously so there is always a flow. Does anyone have any advice on he 'hissing' or the pump noise levels? I'm not that keen to open the bypass much more as it seems a waste of heat?
Grateful for any advice.
thanks!
thanks!
