bathroom downfloe heater
12 Nov 2011
Staffordshire
I have just purchased a Dimplex 2KW downflow heater for which the wiring instructions are not all that clear, Could anyone please advise as to what is needed to intall wiring.
What exactly regarding this heater installation do you need advice on? You have asked a very vague and open ended question!
Rule 1 of electrical appliance installation is to always follow the manufacturer's instructions.
Page 1 of
Installation Instructions state
SUPPLY CABLE IS NOT SUPPLIED WITH THIS APPLIANCE AND IT
SHOULD THEREFORE BE INSTALLED BY A COMPETENT
ELECTRICIAN IN ACCORDANCE WITH THE IEE REGULATIONS.
It sounds like you do not qualify. Get a man in./
The heater will need to be connected to a 13A supply in the bathroom through a double pole isolator. Do you have one? If not you'll need a competent registered electrician to fit one. He will also need to install an RCD to comply with BS 7671.
