Bathroom Downlighter silicone ring
3 Feb 2018
hi all,
First post - been driving myself potty.
Replacing the 12v halogens in my bathroom, noticed the silicone ring / moisture seals have started to perish, and some have even snapped.
Try as I might, can’t find anywhere to buy them - guessing that without them, moisture could get into fitting and cause problems….?
They are bathroom rated ones, but want to be safe.
My second question is a little bit bizarre - have ceiling fans with gu10 halogens, like spotlights you can angle and move, however the bulbs touch the sides of the housing as it’s quite a snug fitting - so they rattle when the fan is spinning. Just replaced with Philips leds, so want something to put around the edge of the bulb, bit like the silicone seal above but a bit thicker, so it helps stop the rattle.
Can anyone help ?
Next question will be on 12v halogens to leds and transformers, but that’s for another day - one step at a time lol
Thanks for any ideas!
If you know the manufacturer, ring them and ask nicely and maybe they will stuff some in an envelope for you.
Well when another day comes just change them to 240v LEDs with new fittings. No advantage in using 12 v.
