Bathroom drop ceiling
17 Aug 2005
London
I'm planning on fitting a drop ceiling in my bathroom so I can fit spotlights and hide pipes high up the wall... Somewhat going into the unknown but after doing lots of searching, this is my plan:
- Screw 2x4 ribbon around the edges of the walls at the height of the new ceiling
- Fit 2x4 joists across the shortest length of the room from joist hangers attached to the ribbon
- Wire transformers for spotlights and a new extractor fan to the existing ceiling rose- planning a Low Voltage Centrifugal pump as the duct is a good 5m before the exhaust
- Cut holes for spotlights and extractor fan grill in 9.5mm plasterboard with tappered edges
- Cut and nail plasterboard to the 2x4 across the room, fitting the spotlights and fan to the
- Fill and smooth the spacewhere the plasterboard sheets join
- Seal edges with wall with flexible sealant
- Paint
The room is approx 2m x 2m.
A few questions I'd be really grateful if anyone can help:
- Does this sound about right!?
- I'm guessing 6mm MDF would be easier to handle and lighter for the ceiling panels, but I'm worried that where the panels join the join would show up through the paint
- Would I need to plaster the entire plasterboard or would filling the joins of tappered sheets be OK?
Any advice would be very much appreciated.
If you can get someone to do it, plastering would be more straightforward for you.
You may have problems with the edges using flexible sealant.
You didnt mention tape when talking about the joints...this is crucial
Try and use tapered edge boards, it will make filling the joints easier if you go for this option.
If, after taping and filling you can still see the joints you could always opt for papering the ceiling.
MDF is heavy stuff, you're better off with the 9.5mm plasterboard.
I'd use decorator's caulk rather than sealent for any gaps at the edges.
Thanks very much for the response, unfortunately I have no excuse not to get started now...
