Hi Guys,
A colleague at work mentioned this site to me to seek advice, so here I am!
I own a typical bay fronted 1930's house, which had the electrics updated prior to me moving in as I have the paperwork (4 years ago). However, the bathroom light was and has always been just the original / normal oldschool rose fitting with a shade and bulb, although the bulb has always been exposed to moisture from the shower. I've never really thought about it to be honest as it has been like that since I moved in and has been fine. I removed the unit and it didn't show any signs of moisture damage.
This brings me on to my issue, I have recently been decorating the bathroom, and fitted a spotlight unit to the ceiling, however I have noticed that it is not IP rated (have recently found out about the IP ratings). Common sense said to me when fitting the light that I needed to seal the unit, so I wired in as normal and sealed the units plate to the ceiling with a silicone bead and used rubber washers on the back of the bolt units that attach the spotlights to the base to seal them. Anyway I've now found out about the rating system and so I'm looking at changing it, however I wanted to know what the main difference is between an IP rated unit and my unit I have fitted (other than the testing, IE seals etc).
As mentioned I have sealed the base unit, but the cups that hold the GU10's have no seal on them and a small vent on the back of each cup facing the ceiling to release heat I suspect. So will this be dangerous in the mean time until I replace? I suspect it should be fine temporarily given GU10's are used in bathrooms and I have sealed the unit, but I just wanted to be sure as I am going to mail order the IP44 rated ones later this week and it may be a week or so before I recieve them and then fit it?
The current position of the lights would mean it is zone 3, it's away from the shower in the centre of the ceiling, but I heard that zone 3 is the entire ceiling and rest of the room if a shower is fitted. I do have an extractor fan and always have the window open when showering, but it does still build up condensation.
On looking at various pictures, it looks like the main difference is that the gu10's normally stick out, and a seal is present around the back part of the bulb to stpo moisture, but as I'm not clued up on this I wanted to check.
Many thanks,
Steve
Many thanks,
Steve
