My bath is in an alcove and I would like to fit lights in the walls at each end of the bath. These would be about three feet above the bath and would be of the circular metal surface mounted type and suitable for use in Zone 1. I would plan to run them off a spur from the lighting circuit that already feeds the existing single light fitting in the room.
I also plan to add an illuminated mirror to the bathroom having an integral pull switch. I plan to run this off another spur off the lighting cicuit via an FCU mounted in the boarded loft space above the bathroom.
Can anyone see any problems so far? If not, my query is should the lights near the bath be protected by and RCD and where should it be fitted, bearing in mind at present I only have a Wylex CU with seven rewirable fuses and a 45amp cartridge fuse for the shower. Yes I know - that needs RCD protection too and I have some queries there, but will raise that as another thread for that.
Although the proposed bath lights have earth terminals in the metal casing do they need linking to the supplementary bonding within the bathroom?
Finally in the bathroom, is it ok to run a ducted shower fan and light off a spur from the ring main in the roof via an FCU in the roof space usung 1.5mm T&E?
Very finally I am aware of part P and will have all work inspected by a competent electrician on completion.
