The bathroom fan has never worked since we moved in a few months ago. Today I decided to have a look. I figured the fan was broken so bought a replacement. From my research, both are inadequate but I wanted something functioning and didn't want to make a larger hole. We are going to redo the bathroom at some point in the next couple of years.
Original - vent axia vimpt100
http://www.diy.com/departments/vent-axia-silver-bathroom-fan/190716_BQ.prd
Replacement -manrose vlp100stc
http://www.diy.com/departments/manrose-silver-plastic-extractor-fan-timer/34879_BQ.prd
First surprise was the wiring on the original
The live was to the permanent live feed, the neutral to neutral and the earth to switched live. I disconnected it and found there was only a live red and neutral black feed - the earth wasn't wired to anything.
Second surprise once I took the covers off both fans was this:
Both fans were the same underneath. I wired the live to switched live and neutral to neutral. Nothing happened. I changed the Live to permanent live and still nothing. In both situations, turning on/off the light, shower isolator and electric shower in all combinations result in nothing happening. Waving the neon power tracer pen shows the feed is live.
What can I do next to work out where the problem lies?
The feed in the wall comes from the loft so I'm going there to have a look.
Is there a way to test the fans themselves are working? Could I wire a three pin plug and test that way?
