Bathroom extractor fan pull cord switch broke
14 Jun 2006
The pullcord switch for our bathroom extractor fan has broken and needs replacing. The switch directly controls the fan turning it on and off, it has no timer.
I bought a new 2 way 6A pullcord switch thinking this would be OK, but on looking at the existing switch it has black+red wires coming to one side marked IN and black+red wires on the other side (ie 4 connections in total not counting the 2 earth).
My new switch only has L1, L2 and COM. I've got a feeling the existing switch is a double poll? Presumably I should only replace it with a double poll and my new switch is no use?
Any advice welcome!
Thanks.
Yes, you should take back your switch and obtain a double pole one
You could make it work by joining the neutrals and just switching the phase, but I'm 99.9% sure the switch is an isolator in this case and must switch all live conductors
I'm afraid you are correct on all three counts.
Sorry.
Wow, thanks for the quick replies chaps!
I'll try and find somewhere local selling a DP pullcord switch...
Thing is, why is the extractor fan switched like this but presumably the light switch just uses a single pole one like I purchased?
Like adam said in your installation the pull switch is acting as an isolator to the fan rather than a switch for it.
