bathroom extractor fan
6 Jan 2006
Sussex
i have a bathroom extractor fan with integral on/off pullcord...the intructions requires it be connected to a double pole fused spur...i've checked the "refernce" pages but these refer to three core + earth and three pole isolation switch!....can mine still be connected via ceiling rose and if so can anyone provide a wiring diagram...many thanks
i assume you stopped once you got to the TP isolator then?
try lookin at the last post on the first page
yes!, i have noted the final diagram (page 1) but doesnt this refer to a fan NOT located in a bathroom?..how do i replace a switch with a double pole switch if it is located in a bathroom and also my fan has a fitted pull switch...can i not use the ceiling rose as the supply and run to a isolated switch then onto the fan?
