I need to fit a new bathroom extractor as the one that was in when I when I bought the house is broken and only vented to the attic space.
As its a large bathroom I want to use a 6inch inline extractor which will then need converting into something smaller/narrower to go down between the skelling and the felt and out under the eves.
Something like this isnt quite designed for it, but I presume it will do the job? Goes into a 200*60mm square duct designed to go out into an airbrick.
http://cgi.ebay.co.uk/ws/eBayISAPI....akeTrack=true&ssPageName=VIP:watchlink:top:en
Would you then expect there to be a shutter somewhere in the pipe/fan to prevent draught when the unit is switched off?
Rather than having it on an auto timer I though I would put it on a separate pullcord so it is only on when your showering not if someone uses the loo in the middle of the night.
Daniel
Daniel
